Richard Hurst
My big Rock blx 3s has a wining noise I just put a new slipper clutch set in it
Its in the manual booklet under maintenanceDo you know what the stock diff oil is in the Kraton. I can't find it. I ha e seen it in this forum but can't find it for the life of me lol !!!
Stock if all LSD is 10k/100k/10kIs 100k too thin for a Kraton exb with a max6/1650 combo in the center diff? I want it to handle well without a lot of oversteer as I am actually going to drive it on the track some. Pretty sure all 3 diffs are LSD as its a newer Kraton. I plan to tear them down soon and put in vitavon aluminum diffs with M2C output drives.
I am fine with the stock weights for now. Just looking to see what others have done who don't bash all the time.Stock if all LSD is 10k/100k/10k
If you are not getting the control you want on stock, yes up the center. More weight in the center helps control the power bleed from F/R for better control. Good place to start.
I have this dilemma, which I’ve been pondering for a while!Here's a useful chart to help you choose what weight thickness you should use your front, center and rear diffs.
Great info thanksHere's a useful chart to help you choose what weight thickness you should use your front, center and rear diffs.
Nothing really happened I think, not that I know of. I like to race freestyle with my son, just blasting around the neighbourhood. I've noticed the problem first on vacation in the woods,.at loose terrain. At home I drive at all sorts of surfaces.What has changed between it didn't happen and now?
Steering radius at full speed will always be hideous, thats just physics.
At lower speed, something like 50/300/30 might work better.
If going to the track with it. Drive it as is first. Keep the stock oil weight in the beginning and learn to drive it that way. The only way to judge what's best for you and how you drive.I am fine with the stock weights for now. Just looking to see what others have done who don't bash all the time.
