Notorious Differentials loud and clunky in Arrma Notorious
damiyo
  1. Notorious
So now that I am up and running I have noticed that the front and rear diffs on my Notorious are rather loud and clunky. Normal?
As mentioned above look up threads on shimming your diffs. You will need to buy a shim set and also shim the ring and pinion gear until it's smooth. Sometimes you'll just need a single shim on the ring gear side other times one opposite side just have to see
