I run the same front and rear in my Kraton, but ear plugs in the center diff. I’m actually working on switching my Outcast diffs over to the same this weekend.
I run the same fluid setup with an 1100kv 5687. Front balloons a little, I've considered plugs in the center but I don't want to shear the pins off the rear CVD's.
I started having problems at some point but then I limited the shock travel in the rear and it stopped it from happening. I took the shock perch off and slid some nylon washers on the shaft (maybe 13 per shaft I don't remember) and it never happened again.
