Sloclone100
I have been in electronics for many years. I will not bore you with a resume but I can solder, that's my message. Those EC% connectors, although they look bulletproof a problem with a lot of people is soldering them. I have more than enough tools to do any soldering job but a lot of guys out there have nothing but 'pencil irons'. I'm saying you need a welder's torch, but you do need heat. With the EC5s' the soldering is pretty straight forward especially if you have a jig for connectors. Then the final 'snap-in' part, well, I don't always get a solid 'snap'. We are now dealing with much thicker wire on our batteries and ESCs'. When you solder that connector on, it has to be straight on and NO solder on the out side of the connector. Even that does not ensure you a clean snap.
But when you finally get that down, I noticed something weird while soldering a male connector on. The heat of my gun spread the connector's brass fingers apart and the male end would not go through. I don't know how I noticed but I used a tool to squeeze them in a bit and guess what? I got my 'snap'!
So if anybody is having the same problem, check this out. It is only for male connectors. HTH - Dave
