skrrt_bert
- 4x4-Mega
So I've had the Granite since February and put a 3800kv system in a couple months ago. For the most part I have no complaints, one broken input shaft and a broken slipper hub the other day, I'm only running 2s and it's a blast. Yesterday my fears were confirmed however; I noticed every time I took the power module apart it had loads of grit and rocks inside. Little bits were getting caught and pressed into the teeth of the spur and really started eating away at the pinion, so every time I had it apart I would try to pick the rocks out of the spur and clean everything in there really well. Nevertheless, it was only a matter of time before the pinion turned into razor blades and stripped the spur in middle of a really great sesh out in the desert. So I'm wondering if anyone has come up with a way to keep debris out of the stupid hole in the power module. I was thinking silicone or closed-cell foam but I really can't fathom how to do that and still be able to get the module out easily. Maybe there's a different solution entirely? Hope I haven't been too long winded, I'd appreciate any thoughts and input on this. Thanks!
