TectalDaedalus
New Member
- Kraton 6s
I'm in desperate need for some help! On my second battery pack on my brand new Kraton v4, I managed to run into a light post and break the front lower hinge pin block (composite suspension mount, I believe Arrma calsl it). In order to get to it and replace it, I think I need to disassemble the front. In order to do so, I need to unscrew the front two top screws from the steering posts. My problem is that those screws are totally stuck, and they are now starting to strip. I've tried with quality hex tools, butane heater, soldering iron and even a dremel and a flat iron. Also tried to unscrew the posts from the bottom, but same story. They won't move at all! Any suggestions, how I can get them out? With the amount of heat I've applied I can't believe this is just because of Loctite. Are they opposite threaded or something?
I'm really starting to loose faith, and are wondering if trying to drill the screws out is my only option now. Any ideas are welcome.
