elschizo
After I broke the screw inside my 4S axle and i didnt get any new ones I looked for another solution.
After toying around with the standard 4S wheel hex and noticed that the channels on the axle make it hard sometimes to properly set it with the grub screw and that creates wheel wobble.
To fix this:
Take a standard 6s wheel hex and put it on the axle. With the long Kraton ones you have to grind down the backside a little. Pin fits perfect.
Did test it on 4s on the weekend - works great.
Has following benefits:
- Sits better on the axle - almost no lateral play - no wobbling - more contact than standard 4S hex.
- Standard 17mm nuts not the small ones
- additional lock screw locks it in even better
- sits on the inner side of the bearing and rotates the same way as axle - so additional friction or heat.
Should work also on the 3S models too - if the axles arent to short ..maybe with smaller hexes from 6s typhon/talion
If somebody is able to design a new axle without channels and a 4mm threat - then I think thats a real improvement.
To fix this:
