- Notorious
- Talion
- Typhon 6s
Would it be very difficult to put some decent threads on a suspension pin with a $20 tap/die set from Lowes?
I'm experimenting with different rear hub options on a 1/10 rig and was considering using a suspension pin from the Typhon. I would need to shorten the pin so I was just going to cut it shorter with my Dremel and then I would need to rethread the end for a locknut. Lowe's has a Kobalt tap and die set for M3-M7. Never used a die before and just wondering if this seems like a reasonable idea or am I overlooking something? I figured the set might come in handy occasionally for doing custom builds.
