Jluther@becoinc
- Senton 6s
- Talion
Mmx8s is alot better than max6 for on road ripping?????you should be able to fit any esc in infraction..imo max series are great off road escz...very tough....Mmx8s and xlx2 are the go to esc for on road ripping...max6 I had my best speed was 100mph..Mmx8s 137 an climbing.
Ok thanks guys.!! So the mmx8s will be better than a MAX6. This is the first on road car I’ve owned. It’s totally different than a off-road set up . Thanks again guysWhat are you running for gearing? I had the same motor/ESC in my Limitless and couldn't push past 116. It wasn't getting super hot, but that was with standard 100mm Hoons, the 107mm Felony rears add a TON of rotating mass. I'd highly recommend the MMX8S/1717 combo over even the MAX5. Hobbywing limits the power output of their ESCs, castle doesn't
Right now I have 22/40 gears in it but I am thinking about putting the stock 46 back in. Ideally I would like to produce a 80 to 90 mile per hour car that can be bashed around for an hour with out overheatingOk thanks guys.!! So the mmx8s will be better than a MAX6. This is the first on road car I’ve owned. It’s totally different than a off-road set up . Thanks again guys
