Kraton Do the M2C outdrives for the EXB 29mm diff have a longer cup than stock?
HZRDOS
  1. Kraton 4s
  2. Outcast 4s
  3. Outcast EXB
  4. Talion EXB
Do the M2C outdrives for the EXB 29mm diff have a longer cup than stock? Had a dog bone pop out on the front of the Kraton and Outcast EXB. I have removed the front spacers, hoping this will be enough - but if there were a drive cup that was a few mm deeper - that would help.
I don't want to trim the ends of the arms to bring the dogbone in a little - it places stress on the dogbone and presses out on the CVD, creating resistance when turning or rotating at full arm extension (yes - I have set the droop screws, but done want to lower it much more). I trimmed the one on the Kraton a little, and this happened - so had to add a small shim on top and bottom pillow ball so it would not bind the CVD joint.
Here is a link to the cups:
https://m2cracing.net/arrma/563-m2c3185-arrma-differential-out-drives.html
I measure 11.47mm from the deepest part where the pin sits to the tip of the cup.
M2C
M2C
Man, going to make me remove the stock diff to check it I guess. Lol. Have any stock ones around? I tried to measure on the car...but couldn't get an accurate measurement.
Nope I bought M2C as spares. I have four cars with EXB diffs. All stock cups. But no more stock spares.
