Do they have metal wings for outcast 6s?
Saladfingerz
Ohio
  1. Outcast 6s
  2. Senton 3s
  3. Vendetta
I'm curious if they have a metal wing for the outcast 6s because I have noticed just after a few bad flips and some roof skids across concrete the wing is worn down quite a bit. So I'm wondering if there is a metal wing out there or even a different material that doesn't just immediately get ground down by the concrete.
3D RC mount because it flexes out of the way.
Have seen some fold sheets of thin 2mm aluminum over the high points on the wing then drill and bolt it to the wing. They can replace it when its worn and a strip of its 10-20 pairs and less then 20$ depending were your are getting it.
I've seen them for the Kraton and the Typhon but not the Outcast.
I would never do an aluminum wing on an rc car that just sounds like a bad idea and a quick way to destroy a wing mount.
