Senton Does a stock Senton 3s wheelie at 75%?
Too heavy and not enough power. It's not really geared for pulling wheelies.
The only "wheelie" you'll get is at full throttle when the body starts parachuting.
I own 4 of them in various configurations and none will pull a wheelie off the line.
maybe this helps: default punch setting is 3. go up to 5 to get instant torque/rpm from the very beginning. downside: increased stress, heat, wear on spur gear, diff, slipper clutch, tires. because of the many plastic parts used, the 3s line is sensitive to early wear. just keep that in mind.
personally i don't like wheelies. i run my senton on punch setting 2 to reduce stress, heat and wear and better driving control. However it does wheelies all the time at 80/90% power (seamlessly adjustable at my DumboRC X6 radio). Is there anything that helps against parachuting?
