Big Rock Does any one know if shock towers swap?
Sir Kushington
Kona. Hawaii
  1. 4x4-Mega
  2. BigRock
  3. BigRock 4x4
  4. Felony
  5. Fireteam
  6. Gorgon
  7. Granite Mega
  8. Infraction
  9. Limitless
  10. Kraton 8S
  11. Kraton 6s
  12. Kraton EXB
  13. Kraton 4s
  14. Mojave
  15. Mojave 4s
  16. Mojave EXB
  17. Mojave Grom
  18. Nero
  19. Outcast 6s
  20. Senton 6s
  21. Talion EXB
  22. Typhon 3s
  23. Typhon 6s
  24. Typhon TLR
Can you swap the shock towers on a big rock over to a kraton 6s? Thanks in advance
Yes.
They are direct swap compatible.
Thank you very much they are super cheap right meow
I've purchased parts from them.
They will fit the V3 Kraton. Might sit a little lower, those towers look taller but it'll bolt up. Got several shock mount positions to choose from.
Does it matter that its v3 kraton?
Yes it does. The suspension geometry is different you need the rear a arms too.
No you can't run the new shock towers with the old arms the shock mounting locations changed and it messes up the suspension geometry. I tried it handles like complete ass.
You're right. Dang. I forgot the A arms are different. And the droop screw wings are different too V3-V5, right? Can of worms.
Eh the new arms will work on the V3 chassis, you have to shave off a very slight amount of material and the droop screws will hit the ears but just barely. I think Rpm made their a arms to work with both but don't quote me on that.
This is a V2 M2C chassis.
