jondilly1974
Speed running apprentice, motor Slayer 🤘
- Toledo, OH
- Granite
- Infraction
- Kraton 6s
- Kraton EXB
- Senton 3s
- Typhon 6s
- Typhon 3s
- Thread starter
- #21
Well I’m about 600ft elevation vs your 4200ft. Pretty sure that has an effect right there.Yep come on you should know I've got gp5's Also running BSR 103mm foams. I would almost think they would even out in the drag aspect as I'm also open wheel where your not so we both have some degree of higher drag. I'm at about 4200ft elevation and been running in low 60's for temp. Just seems for some reason your system is being stressed a lot more than mine. Not sure if Perfect Pass is that much different than your throttle speed feature and that's possibly it just really don't understand why the two setups are not running a lot closer numbers in the logs?
