does "perfect gear mesh have a sound to it. I vote YES I hear it the most when its just slow rolling after you give it power. Thoughts
I didn’t say cheap vacuum cleaner I said hobby grade RC. Some people!only traxxas could make “perfect mesh sound bad!!Yes.
Sheshhhhh I haven’t seen a URC in ages. 2006ish I remember him being banned from Traxxas forum, along with many others including me.I didn’t say cheap vacuum cleaner I said hobby grade RC. Some people!only traxxas could make “perfect mesh sound bad!!
This is so much easier to do on an arrma! stupid mounts for traxxas go up and down so "backing off" slightly is the impossible part. I literally had to use the paper trick just to force a space in betweenJust push the Pinion against the spur tight, then back off slightly. Just need the slightest amount of a "Tick Heard" when you rock the Spur gear at 4 places on the Spur's rotation. I like my Pinions on the tighter side. Mesh wears better.
I can hear the whine/pitch when I run the rig. If it is correct. It is a feel/sound you develope over time.
I set mine pretty much the same way you do.never had a issue .set my mesh on my big rock 4 months ago and still sounds great.its easier for someone that's experienced with this than a new person to the hobby because like you mentioned it's the sound of the right pitch of clicks it makes that you know when it's right.when you learn that perfect click sound then you'll know when it's right or when it's wrong .for the inexperienced hobbiest you can allways try running your rig and periodically check and see if your gears are wearing down un even or just to fast.i think that setting the mesh on arrma is a lot easier due to simple motor mount settings.Just push the Pinion against the spur tight, then back off slightly. Just need the slightest amount of a "Tick Heard" when you rock the Spur gear at 4 places on the Spur's rotation. I like my Pinions on the tighter side. Mesh wears better.
I always loctite my pinion grub, only thing that works for me is red.Any of you guys use lock tight on your grub screws or motor mount screws? I'm sure if your a basher it's probably a good thing to use but as a speed runner is it necessary? I don't use it because I never know the right amount to use and don't want to deal with stripped grub.so far I don't have any problems with any grub screw or any screw getting loose.before I go out and do my speed runs I always hand tight everything down as a precaution.might seem like a pain to allways check but I don't mind doing it.
Still better than the Arrma 3s line. I'd take a Slash 4x4 10x over before ever touching one of those giant piles of poop.I didn’t say cheap vacuum cleaner I said hobby grade RC. Some people!only traxxas could make “perfect mesh sound bad!!
I gave my son a typhoon 3S for this 7th birthday lasted 2 months I gave it to the neighbor kid for FREE! Gave my son my first EXB 6S. That’s the only 3S I’ve ever owned (Arrma brand) that was 2 years ago almost. It’s 6S or nothing when it comes to Arrma!! I’ve had traxxas in the past 2005-2009 nitro Revo and 1/16 E-Revo.Still better than the Arrma 3s line. I'd take a Slash 4x4 10x over before ever touching one of those giant piles of poop.
Oh you had the Turd Revo VXL that explains why you hate Traxxas.I gave my son a typhoon 3S for this 7th birthday lasted 2 months I gave it to the neighbor kid for FREE! Gave my son my first EXB 6S. That’s the only 3S I’ve ever owned (Arrma brand) that was 2 years ago almost. It’s 6S or nothing when it comes to Arrma!! I’ve had traxxas in the past 2005-2009 nitro Revo and 1/16 E-Revo. View attachment 257429View attachment 257430
I really miss his videos and the URC forums. So much information there just gone forever. Some of it was saved by the wayback machine though I can't seem to get The wayback machine page to even load at the moment.Sheshhhhh I haven’t seen a URC in ages. 2006ish I remember him being banned from Traxxas forum, along with many others including me.
