Thanks for the answer, the 20 tooth pinion comes included in the car, right? And also, could you recommend a good onroad tire to use? I hear people recommending Proline a lot, but I only know Badlands and Shockwave (I think both are for mix off/on road, right?)Should have no problems with over heating on 6S. Watched some vids showing the motor runs around 140 degrees after 15-20 mins. Anything under 160 is fine. You will need to change to the 20 tooth pinion to get to 70mph though. The stock 13 tooth won’t do 70
Yes, the 20T pinion is included with the car. The stock pinion installed on the Talion is 13T. Also yes, the Talion will do 70mph with the included 20T pinion using the stock tires. However, Arrma recommends "ONLY" using the 20T speed pinion for speed runs and not extended every day bashing. Keep in mind, the stock Arrma pinions are not good quality and wear out quickly. I would recommend a 16T-18T Tekno or Robinson Racing pinion if you plan on bashing. This should also offer excellent speed. Always use a temp gun to keep an eye on temps when changing to a larger pinion.Thanks for the answer, the 20 tooth pinion comes included in the car, right? And also, could you recommend a good onroad tire to use? I hear people recommending Proline a lot, but I only know Badlands and Shockwave (I think both are for mix off/on road, right?)
I'm not sure what size pinion you are looking for, but here's some links:Can you point to a specific part for each manufacturer?
Badlands have great traction with the moto-x tread pattern. They can be used for any type of terrain, but if constantly on pavement, it will wear out the tread quicker.
No problem and glad I was able to help. However, I don't use a motor fan on any of my Arrma vehicles, even with larger pinions, so I cannot answer your question. However, I don't believe this Castle Creation motor fan will work on 1/8 scale motors, as I believe this is for 1/6-1/5 scale larger motors, like the Traxxas X Maxx, Losi Five T, etc)?I see... Thank you for helping, does this fans for motor fits the Talion?
https://www.amainhobbies.com/castle...dual-fan-shroud-w-fans-cse011-0019-00/p199728
Maybe this one fits, it's 1/8:No problem and glad I was able to help. However, I don't use a motor fan on any of my Arrma vehicles, even with larger pinions, so I cannot answer your question. However, I don't believe this Castle Creation motor fan will work on 1/8 scale motors, as I believe this is for 1/6-1/5 scale larger motors, like the Traxxas X Maxx, Losi Five T, etc)?
