I disagree i have dogbone driveshafts on one rc and when the arms were too much down the car would handle like complete poop after i have put droop screws and adjusted the suspension car was running smootly over extension in a dogbone is possible if the angle is too highDroop screw prevent the shock rods from ripping,they won't help with popping the dogbones. The dogbones will pop out in upmost extension (almost full shock compression) aka a messed up landing on one wheel or similar. Same is true on Kraton etc.
Droop screws are important as well and easy to set, Youtube is your friend.
#1 fix, don't have messy landings but easier said than done.
