It’s a spectrum firma 2050kv 1700 on prep bsr purple foams I feel like it has a 1.9 just new to this and really thru this togetherThat's a damn good time already, considering the size motor your running. What motor is it, size, and KV? My personal best in my drag Infraction was 1.98, but I was running 8S with a Castle XLX2 and a TP motor.
I’m not actually into drag racing but just try a 1 tooth smaller pinion and see if that does it or you may find 1 bigger could work as with your gearing near the end of the run you might be running out of top end acceleration, just my thoughts. Also, where did you get that centre brace from?Tryna get into the 1.9s any fast guys out there with point outs
Looks to be the Perfect Pass CF kit.I’m not actually into drag racing but just try a 1 tooth smaller pinion and see if that does it or you may find 1 bigger could work as with your gearing near the end of the run you might be running out of top end acceleration, just my thoughts. Also, where did you get that centre brace from?
