MeanRichie3
- Granite
- Infraction
- Limitless
- Kraton 6s
- Outcast 6s
So 25/40 may be a decent option for such a high kv motor like the 3200 but if don’t work I’ll use it for something else
That’s the hardest part ?Well I went with a 21 pinion 40 spur and it’s a beast but will not go straight yet??
Balancing the weight distribution across the car and wedging the shocks are next steps. Also balancing each wheel, adjusting the power to build gradually instead of instantaneous when you pull the trigger. Building the car is easy, tuning is complicated.Well I went with a 21 pinion 40 spur and it’s a beast but will not go straight yet??
I'm running the kill mode 2900 What is the best Gears to use on this motor for Drag Racing a 132'Well I’ve only been doing this stuff seriously since November so I may be way off base and go a totally different route but I was thinking like a 25pinion 40 spur but I was trying to get some ideas before I put it together
Do you plan on racing on a no prep track or a prep track? This will determine how much power you can actually put on the track. Why 8s instead of 6s? 6s can be a better choice depending where you race. A lot of racers are using the 4070 2200kv TP motors for 8s drag racing and others are using the 4050 2300kv TP motors. There are also many other larger 1/5 motors you can choose, but they are heavier. This requires a lot of tuning to get the power down track especially when you're racing a lighter 6s well tuned car. Just some things to think about.I'm building an Arrma Infraction 8s drag racer what motor and kv would be ideal for lots of torque off the line and consistent power all the way through.... and that pinion and spur gear combo?
I will try this thank youGet some S1s and it will dead hook
I just did a 3.000 188ft. Is that a good number or should I be shooting much lower? It was my first time doing 188ft pulls, so I honestly have no idea.Looking to run low 132ft numbers, not melt tires running 3 seconds LOL.
If your time is faster post it up!!!
Ive since done a 2.860 in 188ft and can’t imagine getting tons faster without tire prep.I’m running 2.34 in 132ft
don’t know what it would do in 188ft
Sounds fast!!
