jondilly1974
Speed running apprentice, motor Slayer 🤘
- Toledo, OH
- Granite
- Infraction
- Kraton 6s
- Kraton EXB
- Senton 3s
- Typhon 6s
- Typhon 3s
My stretched Senton drag setup that started out as a Typhon, stretched with a Mojave chassis, then swapped to Senton width, Limitless towers and shocks, and now Limitless body, seems to kick out the rear end on a drag hit at right about 132ft. It leaves real straight no problem. But at higher speeds it seems like the rear end is overdriven. Center is a spool. Front and rear are GP4 EXB diffs with aluminum locker inserts. Tires were Sweep Max Forward, matched set. I have a small rear wing for rear downforce. Trimmed Limitless winglets up front. Shocks are travel limited via fuel tube bump stops. Can’t figure out why the rear end whips out like this. I will post a short vid here in a little bit.
