Dreadstar
I picked this truck up at the beginning of the month,just the box stock RTR because,A) It was cheap,B) I've been watching youtube vids on it since Jang reviewed the truck back in 2012.
The first thing that I did on receiving the truck was, to replace the wheels/tyres with Fastrax Bloc Buster SC wheels/tyre combo. The interesting thing here is that the off-set used by Fastrax is a perfect fit,giving a front width of 295mm and a rear width of 300mm. Although quite worn now,I've been using them on a 4WD truck,they are a soft /medium compound which was slightly sticky when new,but they really hook up on most surfaces,Grass/Tarmac/gravel. I don't know how they'll perform on a groomed track,something that we don't have over here,or Astro,which I haven't tried them on yet. They are a massive improvement over the kit tyres though,and they weren't very expensive either.(£9.00/pair)
My next task was to strip out the 48dp gearing,(which I personally hate),and replace it with the 57T/32dp spur gear. I stripped out the motor & esc and replaced them with an INIX 60A esc and a SKYRC Toro 3200kV motor, with,and it's a tight squeeze,a 17T pinion. This is as high as you can get,unless you can find one of the elusive 54T spur gears. I had been running the truck on a 16T pinion,as I originally thought that the 17T just wouldn't fit,but being me I gave it another try,and low and behold it slotted in there,with just the correct amount of slop.
Next it was a case of replacing the lower front 'skid plate' with the aluminium upgraded part and making a brace for the front shock tower,which I'm hoping will allow me to add an extra upper mounting hole for the shocks,which will stand them up a bit more.
The only other mini-mod that I've done is to add foam washers to the top of the body posts,to cut out that annoying rattle that you get from the shell.
Fastrax Buster Blox'
3200kV motor
Inix 60A esc
New skid plate
Front shock mount brace
side view of front brace
3200kV motor
Inix 60A esc
New skid plate
