Dreadstar
As you all know,I picked up a nice little Mega Fury last month and I'm in the process of upgrading it,slowly but surely.
First off,I added some vinyl and a few more stickers to the stock shell,to inividualise it bit more.
I changed the stock tyres over to Fastrax Bloc Busters,which give far better grip and added the aluminium front plate to the underside.
Next,I upgraded the motor to a SkyRC Toro 3200kV motor and changed the esc to an INIX 60A brushless esc.
Next,I made up a front shock tower brace and added in another two mounting points on it.
I purchased some aluminium shocks to 'bling' the truck up a bit,they'll only be getting used when the kit shocks finally die.100mm rear & 80mm front,I also had to change the pistons in them to Kyosho ones as the kit ones weren't a very good fit.
I removed the fixed links on the front and rear hubs & replaced them with TA(T3/T4) turnbuckles c/w RPM rod ends.I also changed the ballstud location on the rear hub,from the back of the hub,to the front.
I just received by courier,two Floureon 5200mAh 2s 30C lipo's. I currently have on order,:- Another set of 1/10th wheels/tyres;a 3900kV motor;a set of wheel adaptors 12mm-17mm to allow me to run 1/8th buggy wheels. I just wish that they weren't on the slow boat from China.
This is where I've currently managed to get to on my upgrades.I'll keep you appraised of my progress.
