I have the 12V lithium dremel as well. The packs are starting to not last as long, the variable speed switch is getting a bit weird and sporadically, it won't turn on. Didn't realize milwaukee had an M12. So if my dremel one dies, I'll likely get that, then I don't have to keep multiple battery types around.I have the 12 volt lipo cordless Dremel. Overall I really like it. Have had several corded dremels in the past, and a nicad cordless many years ago. Really I like this one better then all of those. Plenty of power, very long battery life.
But, about a month after I got my Dremel, I saw the Milwaukee M12 rotary tool. Looks similar, and I already have (and like) a lot of M12 stuff. It annoys me that the Dremel batteries don't fit my M12 stuff, in my in 12 batteries don't fit the Dremel. If you set the batteries side by side, it looks like the only difference is the color of a plastic case. But, one of the batteries, I don't remember which one, has one extra plastic tab just so it won't fit. Even more annoying, Milwaukee and Dremel owned by the same parent company, probably in the same Factory. But they made sure the batteries won't fit between these two different brands.
I do and love it.I have the 12V lithium dremel as well. The packs are starting to not last as long, the variable speed switch is getting a bit weird and sporadically, it won't turn on. Didn't realize milwaukee had an M12. So if my dremel one dies, I'll likely get that, then I don't have to keep multiple battery types around.
Anyone have the M12 dremel? Is it pretty torquey? I found that the lithium 12V dremel was powerful enough to do away with my corded one completely.
Milwaukee m12looking for a good Rotary tool for hobby and household tasks.
wondering about the cordless models.
worried that if it hasn’t been used for some time the battery will be dead and needs recharging. Does it need to be on the charger all the time? Hoping that it can hold a charge in the storage case for quick jobs
I always find this a problem with my power drill which takes a couple of hours for a charge.
Leaning toward the corded model if this is the case.
I have a cordless dremel and it sat for aleast 2-3 years and held a charge ?I have heard good things about this tool. Does it hold a charge while not in use?
how quickly does it charge up for quick jobsif it’s dead?
perfect that's what I hoped for. nothing worse than having to make a quick cut and the tool is dead.I have a cordless dremel and it sat for aleast 2-3 years and held a charge ?
Look for lithium powered. They hold their charge for quite a while on the shelf. Typically cost more, but worth it.perfect that's what I hoped for. nothing worse than having to make a quick cut and the tool is dead.
