Big Rock Drive shaft?
MysteriousPooper
11B baby
New York
  1. BigRock 4x4
  2. Notorious
  3. Voltage
Wheel came flying off today. Found the issue between the drive shaft and wheel axle I guess??? Pics attached. Is there anyway to remove red circle pin? You can't see very well but the screw that holds wheel axle into place looks like it just came undone. If not fixable is there any recommended upgrades or should I just order stock set?
MysteriousPooper
11B baby
New York
  1. BigRock 4x4
  2. Notorious
  3. Voltage
sweet thank you going to try now. glad it should be a quick fix this time lmao
Kusher
Texas
  1. BigRock 4x4
  2. Notorious
  3. Voltage
You insert your hex driver 2mm through the other end to get to the crew you need to get at. it is not supposed to come apart at the u joint. Same thing happened multiple times to me and today in fact. View attachment 138112 like so
And also you can upgrade them as well. Mine keep coming apart at the u joint so I have to upgrade them myself
MysteriousPooper
11B baby
New York
  1. BigRock 4x4
  2. Notorious
  3. Voltage
Ah isn't that the same part number? Sweet that worked. Now I have to deal with the issue that is blue loctite on the wheel nut or whatever it is.
Kusher
Texas
  1. BigRock 4x4
  2. Notorious
  3. Voltage
Heat always helps with loctite. Where at exactly? And need to make sure to have. Good set of drivers. I was told MIP I got some little pricey but well worth it no more stripped bolts.
And if you look on arrma-rc.com under optional upgrades thats where you will find that part. Its not a stock item.
MysteriousPooper
11B baby
New York
  1. BigRock 4x4
  2. Notorious
  3. Voltage
Heat will help and also.like I said a good set of drivers. I stripped quite a few before I got these MIP and should have at the beginning.
Would you just apply heat to weaken it and it should come off after cooling down? Or do you burn it off? I have a little gunk on the nuts. Shown
La Dave
  1. BigRock
That's funny 🤣 My Big Rock did the exact same thing during today's bash ¡ Went home and loctited both front axle fasteners (which I should have done when I first got it due to knowledge of problem). Seems like just a matter of time and every Arrma owner will experience the same issues as others.
MysteriousPooper
11B baby
New York
  1. BigRock 4x4
  2. Notorious
  3. Voltage
I jumped and mine flew off st landing. A small jump is all so I was like wtf. Thankful for the easy fix
