Thanks for that tip. Is the internal dimensions for the dog bone cup the same as Arrma? Is it loose? Those are much more stout looking.Or you could use mugen outdrives https://www.amainhobbies.com/mugen-seiki-front-rear-differential-cup-outdrive-2-muge0228/p29852 , that’s what I’m using on mine.
Here’s a comparison picture with stock arrma outdrive
A little advice. The TD outdrives have a ever so slightly shorter shaft. When I opened up the diff I had the area behind the gear that goes on the shaft is machined for the shim. When I went to put the outdrives in my Arrma diff it was to tight on the gear with the Mugen shim. That’s why I just bought up the full diff. The pic is of a spiral gear but the straight cut has the same recess as this.Just brought 2 sets of Durango td310480’s from eBay £30 for the four. May not need them but I’m sure if I hadn’t brought them I would have needed them and not been able to find them
Same internal width just longer so it works with CVD’s in the rearThanks for that tip. Is the internal dimensions for the dog bone cup the same as Arrma? Is it loose? Those are much more stout looking.
Lol, I ordered 2 sets to expert because I need them?.....Same internal width just longer so it works with CVD’s in the rear
