Will these pins work as replacements?
https://www.amainhobbies.com/mugen-seiki-3x12.8mm-joint-pin-mugc0270/p4435#tab-compatibility
I meant as replacements to the ones on the ends of the driveshafts. Kind of wore outWill these pins work as replacements?
Those are called drill bit blanks and are primarily used in the Diffs. As for replacing the pins in your dogbones those pins are pressed in and are serisouly beefy steel, you would be hard pressed to find pins that will hold up as well as the stock ones, also replacing them would be a real PIA. I would recommend replacing the dog-bone plus they are fairly cheap
You make a very good point, had this set for a few years now. No complaints. I decided to buy a new set from Jenny's. Starting my annual winter rebuild on my Typhon. Thanks for your input.ad theseThose are called drill bit blanks and are primarily used in the Diffs. As for replacing the pins in your dogbones those pins are pressed in and are serisouly beefy steel, you would be hard pressed to find pins that will hold up as well as the stock ones, also replacing them would be a real PIA. I would recommend replacing the dog-bone plus they are fairly cheap.
