Mojave Dual motor hobbywing 5690 GT width Mojave chassis street truck
StephenSchandelmayer
Florida
  1. Gorgon
  2. Mojave 4s
  3. Outcast 4s
  4. Typhon 6s
I have posted about this truck here and there but never really did any sort of build thread on it. When the fireteam first came out I was all about it and had to have it. I upgraded it with m2c and JBI parts and what not and it was a great truck for awhile but then I ended up transforming it into a street truck.
I wanted to run a proline UDR body since I felt like they had a really nice shape to them. The biggest issue was the mounting of it since normally the UDR mounts to the cage in the back. So I cut out a piece of carbon that went straight across from one side to the other and drilled holes to slide onto the rear arrma body mounts and that worked out beautifully. The fronts I just used infraction posts.
The truck ended up having Mojave arms, shafts, and front hubs. But the rear needed kraton hubs along with m2c +5mm hexes on all 4 corners to get to wheel fitment that I wanted with 1/8th grps. It also has infraction front tower, shocks, and a carbon splitter. The rear kept the JBI shock tower with the fireteam rear shocks and heavier springs. It has the infraction rear diffuser and a perfect pass v2 batwing. I also locked all the diffs with scorched lockers.
I have been running a tp 5660 1460 kV motor and an XLX2 for a long time, it originally was run on 8s for some speed runs up to 125 and then I stopped and went to just street ripping on 6s
Recently I wanted to upgrade it a bit more so I purchased a scorched carbon mojave chassis knowing that the sides weren't bent up like the aluminum ones are, this allowed me to make carbon chassis extensions for the sides out of the same thickness. It came out great. I also bought scorched outdrives for the front and rear input gears. Then after doing all that and seeing @calebgilmore post up a dual PPS mount for sale I just had to do that as well.....the dual mount showed up today and I'm hyped thank you @calebgilmore 👍🏼. I wanted to do a hobbywing setup because it feels like everyone does castle and tp dual motor setups so I wanted it a bit different. I opted for the max 6 5690 combos which should be arriving this weekend 😁 totally excessive amount of power but I'm super pumped. It'll be run on 6s for fun and probably end up trying some speed runs with it. Idk how fast those g2 max 6 esc will go but I figure for most of my shenanigans they will be just fine.
Pictures show the truck in it's old setup and then it's it's current setup with carbon chassis
Nothing too out of the ordinary on this build but I love it. I have thought about doing a storage pod on the roof to the wing, always thought that kinda looked cool. Like this:
Was this thread suppose to be a cure for erectile dysfunction... Its working.
I was targeting you specifically in fact 🤣
Just got some fresh @RamJamRacing center dogbones ordered up. The current ones have been beat for about a couple years now so I think its a good time to freshen them up before the powa arrives
I Love it!
Let me know if there's something I can help you with on this build. 👊
You might have to design me a roof storage lol. Let me do some mock up tonight. The 3d material can be sanded and painted correct?
More Powa!!
Yes!
Consider it done. 👊
Correct.
Why not? The fumes?
Exactly.
All my printers are upstairs..
near my little girls room. So, I'm not going to chance it.
Exactly.
Totally understandable. I wouldn’t either.
My printers are in a well-ventilated basement which makes things a little easier. A basement is another floor under ground level, in case y’all Texans never heard of it 🤣
Yes.
You guys are SO damn Lucky!!
It's called a bunker around these parts..
There are a few specialized builders/developers who knows how to construct basements here in Texas..
I know one personally.
Just need to scrounge up the funds to have it custom built...
Yes.
A bunker would be so sweet...... But a basement would also be so sweet. Although a basement in Florida seems like a terrible idea. Moist
More scorched 😈
The center brace is for an infraction since they don't have one of them for a Mojave I'll be extending it and drilling some new holes to make it fit
Then I have front and rear hubs and rear hinge pin holders
Got the motors and ESCs in. I'm not 100% sure the ESCs are going to stay where they are. I don't like the wiring situation so I might move them forward to have the wires better situated. I don't wants to shorten the wires at the moment. But it looks pretty amazing so far.
I also got my scorched infraction center brace in, I made a small carbon extender for the rear of it to make it reach the back mounting position. I also drilled new holes so it bolts down to the center diff cover.
I run a @3d-rc.myshopify.com wing mount on this just for looks and I always had it zip tired to the perfect pass wing to hold everything together but now I made some carbon uprights to bolt the wing mount to the existing uprights for the batwing.
Really enjoying this full freshen up of this truck. Makes me love it that much more
