bicketybam
Back from vacation!
- New Milford, CT
- BigRock 4x4
- Granite
- Infraction
- Kraton 8S
- Kraton 6s
- Kraton 4s
- Mojave
- Notorious
- Talion
- Typhon 6s
For anyone interested, this is how I made my slipper clutch.
Parts:
AR310782
Slipper hub
Slipper pad
That’s all you need. The rest is dremmel work. First I cut down the stock spaces to the exact width of the bearing.
Next I modified the second slipper hub (not the original). This is the trial and error part. I modified both sides.
Once that is done you take the shaft and put the cut down stock spacer and bearing on. Then the modified slipper hub. Then a slipper pad, followed by the spur. Add another slipper pad and the stock slipper hub. Put the pin in and fit it all together. Add the spring and the nut and boom. You’re done.
Parts:
AR310782
Slipper hub
Slipper pad
