Notorious 6s basher
Will the Duratrax 6 pak tires run ok on notorious 6s?
Talked to my guy at the hobby shop he said there would be no problem. got snow here cannot try them out yet.Those are some big meats! Gear properly!
Roger that. LHS guys that are selling you the tires saying there will be no problem should be a red flag. Anything you add rotating mass weight to, you'll have to watch your temps by gearing properly. Otherwise, why would you be in here asking if they will work right?Talked to my guy at the hobby shop he said there would be no problem. got snow here cannot try them out yet.
What gearing would you recommend? A higher speed gear? View attachment 271738
To big?Looking to burnout your ESC or motor? Or Both??
To big?
To big?
Sorry new here! Have not had an RC car for about 20 years now I had a old T-max and E-Max! Decided to get back in and try the notorious. It’s sounds like I should stick to The stock tires before going out.Dude, you could've asked this in your other thread. You would gear down.
You can probably run those tires if it will turn BUT you will have to gear it accordingly. You will need to go DOWN in tooth count on your pinion. How many teeth is going to be up to you based on speeds and what your temps read. If it were mine, I'd gear it down 4-5 teeth with those tires and start there. You will most likely need to experiment with a bunch of pinions.
You still have to factor in weight. Even gearing it down to achieve the same top speeds as stock, that motor and ESC will be begging for him to hit a puddle. Don't forget Tire ballooning that acts just like more pinion that will shoot those temps up with the quickness.Welcome, @Notorious 6s basher ! I'm new here too, but this is a great forum!
All things equal (for instance, ignoring the weight differences of the new wheels) you should be able to measure the diameter of the stock tires, and these new tires. The difference of that ratio will help guide how many teeth you'd want on your new pinion. You'd want to adjust your motor pinion gear size (# of teeth) by that same ratio.
Let's say the new tires were 1.25 times the diameter of the stock tires. Say 5" (new) vs 4" diameter (stock). 5/4 = 1.25 , so this is your new tire's effective gearing change.
If your stock motor pinion was 15 teeth, then you'd want to go something more like 15/1.25 = 12 teeth, to match the effective gearing of the stock setup. This would keep approximately the same top-speed, etc.
They are much heavier.They are pretty much the same diamiter as the stock tires.
