Duratrax Bandito for Kraton?
Yep like said above they will work fine just need to make sure you get the 3.8's. Also in my experience Duratrax are not the best quality so make sure they roll fine and I'd suggest balancing them also. The set of Duratrax I bought for my Granite were horrible right out of the package they were really uneven so truck looked like it was going up and down over bumps on flat ground. Can also look at some Sweeps they are really great quality but also cost quite a bit more.
Thanks everyone, Think I’ll hold off for now on wheels. Just looking at my first little upgrade, Might do the bearings first instead. Done the diffs now, They are all the Arrma aluminium ones.
I'd like to get the 2.8 version of this tire for my Kraton. I may give them a shot but sounds like they need some work out of the box like maybe some extra glue on the back side. Wish they were bead locked front and rear. Other than superglue to re-enforce the bead, is there a better glue to consider?
https://www.amazon.com/dp/B08K3H679M
