Yea looks similar mine are part # C25089grey. You have to buy the Traxxas axle pin they are the threaded ones. Traxxas 5145 screw pins. The are same size diameter as stock this set up fits perfect no play at all.
i ordered these integy ones for my senton BLX and they have tons of play in them, the wheel would probably wobble close to a cm.
how much up/down sidetoside play are you guys seeing on these?
Correct so we can run 2.8's like Trenchers or MX28's and maintain cross-compatibility with other vehicles we may have, at least that's my reasoning, I already MX28's from my Typhon truggy.So if I understood correctly, Granite owners are looking for 17mm wheel adapters?
Any details from HH on when part# AR310816 will be available? Still annoys me to no end that Arrma decided to go with 14mm hex when every aftermarket wheel is 12mm.
I've wanted to pick up a set of mx28s but I'm not going to do it until I know I can mount then.
