Van hetzelfde! En hopelijk tot volgend jaarVoor iedereen die het natuurlijk nog leest wens jullie allemaal fijne feestdagen
CNHL, Ovonic, HobbyKing and Gens.Ace. are my preferred lipo suppliers but a lot is sold out.Hey guys, not a Dutchy but I live in Heinsberg Germany which is right near your border and you are all fluent in english, I lick Germans. What 6s battery and charger do you guys recommend to not break the bank? It will be for a 6s Kraton and I’m only interested in a single battery, do t want to stack two 3s. Thanks a lot.
What batteries do you run with it? Also do you need special adapters to plug to the batteryI have this one. Very easy to use and let’s you know if you do something wrong. It’s now on sale.
https://www.toprc.nl/rc-plus-cube-d...3zykw05gq9rbpDfOmMWdjOGPrtjOCtZBoCtC4QAvD_BwE
Of topic: I think You meant you LIKE Germans. Or do you really lick them?
M2, I lick Germans
My grandma was German, so technically if i lick myself i lick Germans partially
Heb je al eens een Triple Kingburger van fatburger als ontbijt gehad?American hamburgers are better than European ones
I have Gens-ace and CNHL. The latter have great deals from time to time and are great lipo’s, so I‘ve almost completely switched to CNHL lipo’s.
I run XT90 connectors so I bought XT90 charging cables (only a few euro). The same apllies if you run EC5 connectors, since neither of those come with the charger.
Those come with 8AWG cable, which are a bit harder to solder/fit into the XT90 connector. Those usually come with 10AWG.View attachment 189504So if I buy theses I just have to cut off the plugs and solder on the XT90?
Thanks alot, and its 30 euro cheaper.Those come with 8AWG cable, which are a bit harder to solder/fit into the XT90 connector. Those usually come with 10AWG.
CNHL does have packs with XT90 ootb
Nope. Tot nu toe alleen maar yoghurt, boterhammen en kippensoep.Heb je al eens een Triple Kingburger van fatburger als ontbijt gehad?
Me too, the frikandellen. Nederlandse frituur is geweldigI want some Bami, Shoarma, Frikandel special, thats what I miss the most. and some Van Nelle- Zware shag.
I last question before I get this, will it fit in the 6s Kraton? Battery tray says up toThose come with 8AWG cable, which are a bit harder to solder/fit into the XT90 connector. Those usually come with 10AWG.
