I’m trying to adjust the endpoints on my Mojave EXB with the Spektrum DX3, I follow the instructions but do not get the blue led. It just turns on Green.This is the last thing to do before taking it out for the first time. Plz help?
The default end point value is 100% for both steering and
throttle/brake. The maximum end point value is 150% with
adjustment.
To adjust the endpoints of the steering and throttle/brake:
1. Power the transmitter on while holding the steering
wheel full right and holding the trigger at full brake. The
power LED flashes blue to indicate the transmitter is in
end point adjustment mode.
Steering:
2. Turn and hold the steering wheel full left. Turn the
steering rate knob to set desired end point.
3. Release the steering wheel and reset the steering rate
knob to full.
4. Turn and hold the steering wheel full right and turn
5. Release the steering wheel.
TRANSMITTER PROGRAMMING
End Point Adjustment ModeThe default end point value is 100% for both steering and
adjustment.
Steering:
knob to full.
