DX3 Radio with bluetooth?
sharkyenergy
Hiya all!
The Kraton comes with the DX3 now... I found this online:
The waterproof electronics module — also designed for easy access — houses and protects more innovative Spektrum™ equipment. ARRMA® has equipped the KRATON™ 8S BLX 4WD Speed Monster Truck with a state-of-the-art Firma™ Smart 160A ESC and SR6100AT AVC® (Active Vehicle Control®) receiver. Innovative connectivity enables all the Smart electronics to send valuable telemetry data to the included Spektrum™DX3 3-channel transmitter without requiring multiple wires, sensors, modules and links. Just download the free Spektrum™ Dashboard App to your mobile device, which connects wirelessly via Bluetooth to the DX2E transmitter. Then you can view motor RPM, ESC temperature, receiver voltage, drive pack voltage and more data in real-time.
does this mean that the DX3 does not require the bluetooth module and has it integrated? could not find a DX3 bluetooth module anywhere.. Only found the bluetooth module for the DX2e...
Thanks
Tremonti
Kraton 8S
Hiya all!
Thanks
That paragraph suggests you don't need an addition BT module, but I can't find any BT related information on the DX3 product page or manual. Only that it's 'Spektrum SMART-ready'. Your best bet is to just call Horizon Hobby, they'll be able to you a definitive answer :)
sharkyenergy
maybe someone who already has it could try to connect with the smartphone.. just to verify if it works or not..
Buckwhea7
Kraton 8S, Kraton 6s
Hey fellas, did anyone figure this out at all? I just got my K8S last Thursday Mar 5. and it was the updated version with the DX3 and new brace system! Couldn't be happier with the truck! The Spektrum dashboard app definitely does not work with the DX3 tho. I can't see anywhere you could install a BT module, and the app says DX2e right on it. So I'm wondering if it hasn't been updated to work with the new radio or I'm just missing something. Nothing in the manual about the app either. I'll probably call HH eventually, just curious.
r4nd0m
Milton Keynes, UK
Granite, Mojave, Notorious
I don't think it has, there is no mention in the official manual the only thing is: "
If using a SMART ESC and SMART battery, the transmitter SMART Battery Level indicator will show the vehicle battery level
within 10 seconds of powering on and binding." which obviously are the 4 indicators on the top
it also doesn't look like there is any option to plug something into it - so of you want smart now its a better transmitter that you need to get I guess
Buckwhea7
Huh! Your right dude!. It’s right there in front of my face🤦🏻‍♂️ I saw that little button thing on top and couldn’t figure out what it was. If you just push it in and lift up, sure enough the little cover opens. I googled it earlier and wasn’t able to find anything except the older DX3 models. Did a search just now and found the website rcmxonline.com. There’s a write up about the DX3 that comes with the K8S, shows pics and says you need the BT2000 module. Searched HH for “BT2000” with no results, other than the DX2E bt module. Hmm.. anyway that’s cool that there’s the option or at least will be an option for it. Thanks for the help guys!
Create account
Log in
