KratonKing44
New Member
Can someone please tell me definitively if this DX5C Tx will bind with either a SR310 Rx (Proboat) and/or a SRX200 Rx (Kraton)
Thanks in Advance!
Thanks in Advance!
I bind mine at 11ms and they work fineI don't think the DX5C works with the SRX200 Rx, but, it may work with the SR310 RX. You need to chose 16.5ms when in the Bind Menu on the Tx. Don't think you'll be able to bind at 11ms on the SR310 Rx. But if you can upgrade to the SR6100AT Rx, that receiver is awesome when the AVC is dailed in correctly.
SRX200
6s felony original receiver is the 6110at will bind but no steering and will not calibrate avc. So I bought a brand new sr6100at and getting same results binding with spektrum dx5c any thoughts
Follow what JKF said and make sure on the DX5C brake and throttle S/R all that is 100% which I am sure you have.No knobs on the dx5c but all end points are 100% avc all the way down. I get a bind but I don't get steering, ability to calibrate and doesn't stay bound after turning off car
