Dynamite GPS Speed Tracker
Found one more damaged part. Replaced with Voltage Hobbies upgrade.
You should double check your bulkheads and make sure you didn't crack them, at least the front one, where thhe upper steering post plate screws to it. I busted both of those ears off mine recently and I didn't wreck nearly as harsh as you did.
I disassembled the entire truck and inspected everything. Bulkheads were good.
