Mojave EASIEST WAY TO WIDEN TRUCK!!!
K-BASH
ST.LOUIS
  1. BigRock 4x4
  2. Mojave
  3. Notorious
  4. Senton 6s
  5. Senton 3s
  6. Typhon 6s
So when I got my Mojave I bashed it stock an had a blast,then I got a notorious.super crazy truck I didn't like how it constantly wheelied an flipped upside down so easy.so I decided to swap suspension on them,huge Mojave,an a less crazy noto.got them both done an the monster Mojave kept blowing diffs after putting the big backflips on it.so it's down for the winter ,big plans for a winter project.downsizing it..while doing swap i realized hubs are different.resently got a senton6 an wanting to widen it ,worked great on senton 3s truck.2 opinions I'm aware of.1st is suspention swap.arms,axles,t-buckles,shocks,towers optional. 2nd option is hubs.hubs is alot easier.mojave,senton6 have same short hubs....k6,OK,NOTO,TALON HAVE THE 1/2INCH LONGER HUBS. a few of you had questions an seemed interested.i couldn't find anything on utube on it so I'll shoot a short video on how an what's needed for swap later when my house settles down some.i got a house full of CRAZY,LOUD,KIDS RIGHT NOW..SO HERES SOME PICS OF MY SENTON6 WITH KRATON HUBS&STEERING BLOCK SWAP.
SUSPENSION SWAP 200+$
HUB SWAP. UNDER 100$
Not sure about the typhon, if I has the short hubs this would work also
So try to put the receiver on each child, reprogram the transmitter, and INSTANT ROBOTS???
I WOULD GIVE IT A TRY IF I COULD ONLY CATCH ALL 4 OF THEM!!?I had to escape to bedroom to install last hub.crazy kids and lots of small rc parts IS NEVER A GOOD IDEA!!!!
Taken today 6s on left, 3s on right.
Second pic was taken the day I bout S6
1/10 widened 3s senton is bigger blx185 7.03lb w/pack
1/8 widened 6s senton.8.21lb w/pack
.same length,S3 wider
For me it would be grandkids......
A
So your running Kraton shocks too?
I was asking if u got the typhon a-arms yet?Mojave are same length just alot stronger.
The shorter style hubs,steering block limit wheel,tire combos you can run,the extra 1/2 inch helps clear bumper,buckles.althou I've never tried hubs on stock Mojave for clearance
Mojave arms are about 0.5 inch longer than typhon arms. and yes they are thicker. They will collide a little on the ears of the chassis ( at least with M2C Chassis) jfyi
Okay I thought they where the same length,I removed a little of the material on arms when I mounted them on my noto.chassis tabs are shaped diff.
I got the Typhon arms on the Senton 3s, still need to do adjustments. I will post pics tonight when I get a chance. I keep thinking about the 6s though, half of me wants to keep it stock, the other half wants to widen it. :unsure:
Once u drive S3 widened you will like.LOT less walking to flip it over,saves body,Less rollovers an MORE BASHING??
Yea I'm really looking forward to how it does, I'll find out this weekend. :cool:
Even thou its s***y here still I had to try new setup.quik little 4s romp at the park next to house.ITS AMAZING I HAVEN'T GOT INTO TROUBLE YET.I BASH MY NEIGHBOR PARK DAILY.50++mph across park leaves flying.noone has ever complained..TRUCK HANDLES GREAT,LESS ROLLOVERS,MORE ENJOYABLE..TIRE RUB A LITTLE ON 4S.6S WILL B WORSE.I GOT MY NEW MEGA BODY TODAY..FITMENT IS PERFECT,LOOKS LIKE IT WAS MADE FOR S6.FRONT WRAPS AROUND BUMPER TO PERFECTION.THANK YOU ARRMA FOR MAKEING SO MANY PARTS COMPATIBLE.GOT NEW WHEELS ON WAY.IM GONNA SPRAY FOAM BODY BEFORE RUNNING BODY.THINNER LAYER OF FOAM THIS TIME.THESE BIG 4.60 INCHS TIRES ARE ALOT BIGGER THAN SCT TIRES.STOCK SIZED TIRES PROBLY WOULDNT RUB TO BAD.ILL TRIM BODY SAME AS I DID BLUE BODY TO WORK ON MY SENTON6.
Check this fitment
That looks mean, that right there would make an awesome V4 if ARRMA ever brought it back. I got my 3s together,
I knew this body fits the 6s, but it won't with the Scorched fenders on it.
Think might keep this stock. I just love the look so much. Retired from frontline duty, exhibition only lol.
Here is a freak I've been working on, would love anyone to guess what this thing is lol.
Handles alot better,bout like adding typhon arms on 3s.raised it a little bit too. I had to tighten up suspension half way throu run.i have always trimmed my senton bodys,follow the crease around wheel well so I can run 17mm buggy tires. Just got blx big rock running again.bout to go thro senton now . They r both set up very similar.they get ran hard and a lot..ordered lighter 4s high kv motor for senton
