Shockwaver
Idea: once you have your wheel nuts off, find an object with a diameter slightly smaller than your axle (a short hex socket maybe?) and put this on the ground. Put the truck on its side and align the axle with the "object". Then you can press on the wheel from the inside. You should be able to put a lot of weight on it this way without risking any breakage...
I love you man!! I'd up vote you an hundred times if I could... could please the admins allow me to just this once??
