Ec5 high heat casing?
speeding_Infraction
Seattle
  1. Infraction
Is there a reason why EC5 connector casings are not high heat plastic, like XT connectors? It seems like that way they could ship them complete.
slick2500
Community Leader
Rapid City, SD
  1. Fireteam
  2. Kraton EXB
  3. Outcast 6s
  4. Senton 3s
  5. Typhon 3s
No they still wouldn't be able to ship them complete as you would not be able to solder wires onto the bullets because they are recessed too far into the housing.
RedOctobyr
Lowell area, MA
Just curious, if we assumed this was an option, what benefit would that offer? Personally, I think the fact that they are soldered as bare metal contacts is a pro, not a con. You can add as much heat as you want (even use a torch), without worrying melting the housing, or attaching a mating connector to help draw heat away.
RedOctobyr
Lowell area, MA
I don't feel that it would offer any special benefit, it was just a thought I had
Cool, you just made me wonder.
I'm going to guess that part of the reason they're a lower-temperature plastic is *because* you have to snap the contacts into the plastic housings. Lower-temperature plastics are generally softer, and it would be easier to click the contacts in. If you used a very-high-temperature plastic, in addition to them being more expensive, they would likely also be stiffer, so it might be tougher to assemble the contacts.
And lets not overlook the cost aspect :) Plus, from a practical perspective., there shouldn't really be much need for heat-resistance, since these are soldered without the plastic. XT90s probably use that because they must, given how you solder them. But it's not required here, it's probably cheaper to go with a less-impressive plastic.
