- SE PA
- Kraton 8S
- Kraton 6s
- Mojave EXB
- Outcast 6s
- Talion
- Typhon 6s
Those glasses are awesome. link?
edit: found them...very cool
Duuuude you are ready to SMASH it. Look at all those goodies. Once you start, your gonna end up soldering the house down2 Questions:
What is “re-tin”? Also, I will Google this Flux stuff.
Again, thx everybody for the input. I’ve been really busy preparing everything I need to solder connectors. Now, I wonder what am I missing? Lots of pics here. Anything else I need?
P.S: I love those Eschenbach Max Detail glasses. View attachment 57051View attachment 57052View attachment 57053View attachment 57054View attachment 57055View attachment 57056View attachment 57057View attachment 57058View attachment 57059
This is why I turn down every hybrid car job. If I gotta use welding gloves to work on electrical systems for a car, I’m not doing it.DC is far more dangerous than AC in general. But it is hard to find a source of high voltage DC in everyday life. I was at an old church once that used DC lights and had a big wheel up on a balcony that controlled the system. On touch of that wheel and you’re a goner for sure. Once you get above 50VDC, bad things start to happen. It only takes a very small amount of current to kill you, but the barrier is you need enough voltage to overcome the resistance in the body to get that current flowing. DC above 50V will usually flow through wet skin on most people.
They look sweet! How many lipos can you fit in there?Peace at last, peace at last. Thank God Almighty, I have peace at last! The Pulse-Bat boxes just arrived. They are absolutely beautiful. Unfortunately, the charger I have won’t sit well on the bracket they provided, but I’ll find a work around. I also need to get balance charger extensions to into the box. It’s a work in progress. The boxes will do fine for storage in the mean time.
View attachment 59688View attachment 59686View attachment 59687View attachment 59689
Thanks again guys for all the help and advice. Things are coming along.
Right now, I’m just following the instruction manual which suggests no more than 2 6S per box. I might order 1 more of these boxes for another set of Lipos for the 2nd Rig.They look sweet! How many lipos can you fit in there?
It says 2 6S when CHARGING. You can store more than that.Right now, I’m just following the instruction manual which suggests no more than 2 6S per box. I might order 1 more of these boxes for another set of Lipos for the 2nd Rig.
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.ca/ulk/itm/361148899374yes if you charge it three times ??
You have a link? I’m thinking $100 is entry level for a new decent iron for this hobby.
