- Nero
Next time bud ????
diffs good is a positive ????
I just think the BLX185 isn’t well suited to speed run. I had one cut power in a Typhon 3S let alone a Kraton 6S. Not much I have found to fix it other than a much longer wind up.Any other thoughts on the amp cutoff @jondilly1974? Would the dual fans I'm running cause this possibly? Was going to unplug the fans next time and see if it still does it otherwise I'm not sure at a loss.... Not a huge deal as I never planned on a speed run rig for the K6s but still fun to do every once in a while and this is just not allowing it.
Ya my mailbox did? I close my store tonight so I'm not off until 10:30pm tonight damn it. But ya your parts and my Jenny's Kraton set came today ? stoked!!Ever get the rest of the parts? My infraction wouldn't even run with the speed gearing right out of the box.
Sure is likely. That would destroy your amp capacity.So possibly found a reason for the cut off on speed runs maybe? Went to run the K6s yesterday and one of my batteries would not register. Took apart connection and found my solder was coming undone so resoldered her up and is fine now. Would this possibly cause the cut off @jondilly1974 in a sense loosing good connection during the run?
Let’r’rip taterchipI'm hoping this was the issue and not the ESC as before switching to the new set of batteries I'm using I did not have the problem so?
Well... did you catch in on RC’s funniest home tumble Wumbles? HahaWell diffs are still great but shock standoff screw, rear suspension hangers, hinge pin and possibly rear shock not so much....View attachment 112430
