It's supposed to be mostly a 6 pole big motor issue where at high rpm's the esc and motor lose their synchronization. Like an engine running into a rev limiter, both motor and esc are capable of more but can't keep up with each other and lose efficiencyIt's hard to describe but I'll try, so the motor will cut out in a sense and not keep climbing in rpms and stay in sync with the ESC. If you watch my previous 8s passes you'll hear the motor climbing in rpms then right at or just after full throttle it almost sounds like it bogs or cuts out and doesn't keep that high pitch sound as it is not staying in sync with what the ESC is telling it to do. @rotauq may be able to describe it better as he's who told me that's what the issue is. Here is a good example of it happening if you listen you can clearly hear when it happens.
