Elevate suspension on a Fazon
Fazoner
sweden
  1. Fazon
Hi, again :)
I want to elevate the suspension of my Fazon so I get more ground clearance without spending to much money. How should I go about doing this?
How far can I adjust the "shock adjustment collar" to tighten the spring before I risk breaking any part of the suspension? Can I use the entire threading?
If I have to spend money what should I buy, are there any kits?
BR
Faz
Before winding down the shock collar all the way, I would suggest looking at longer and/or stiffer spring that won't require you to run the collars down as much.
Shock Spring: 75mm #AR330417
Hot Racing and a few other after market companies also make other springs that work with the Nero platform shocks.
