ridgehead44
- Granite
Good afternoon, and Happy Thanksgiving to all!
Does anybody have advice on how to set the steering end points on a Radiolink radio/receiver combo? I had seen a Youtube video for a Flysky radio, which recommended you turn the wheel as far as it will go with the end points set to maximum. This should cause the servo to buzz because it is being stressed. From there you're supposed to dial down the respective end points until the servo stops buzzing. This should indicate the servo is no longer stressed by the amount of travel, and should allow for maximum steering without stress to the servo
Thing is, I am not hearing a buzz from the servo, even though I have the end points dialed up to 120%. Maybe my motor and ESC fans are too loud? Maybe something is not right with my steering links? Any advice on how to reliably set up the end points with this system? This is for a Granite BLX, btw. Thanks in advance!
