What matters is which transmitter you are using.
spektrum slt3how to check endpoints on a granite mega upgraded to spektrum 3300kv 85amp esc and 13kg servo 6.6v
thanks . I don't see it but I'm sure I'll find itI replied with a video in your other thread, check it out.
hey thanks for video. it worked . can I also do the the throttle calibration even tho my esc looked different from hisI replied with a video in your other thread, check it out.
I’m not sure, but you can try.hey thanks for video. it worked . can I also do the the throttle calibration even tho my esc looked different from his
Can you adjust end point even with slt3??I replied with a video in your other thread, check it out.
Yes you can.Can you adjust end point even with slt3??
yes I did it and worked well. check-out the videoCan you adjust end point even with slt3??
