GaryC
How to set endpoints on the big rock...slt3 transmitter?
No problem, don't worry about that, that's what this forum is for.Thanks man...for some reason it didn't pop up on YouTube last night. Must've typed the wrong thing in...just watched it though
This is a screenshot of the SLT3 manual after a Google search. I would download the pdf manuals for all the ESCs, radio gear, exploded views etc. so it's all at hand when it's neededCertainly have sir...the videos I saw weren't very informative...plus, what's the forum for pal?
You have...I didn't see @razorrc video last night when I did a search... but thank you...This is a screenshot of the SLT3 manual after a Google search. I would download the pdf manuals for all the ESCs, radio gear, exploded views etc. so it's all at hand when it's needed
Well if it's good for one thing, it's to advise and point in the right direction... hopefully we've done that
Followed it step by step as I watched it...then I did the calibration and so now I have only neutral and forward but for some reason when I went full reverse and tapped the set button there was no response...now I have no brake or reverseNo problem, don't worry about that, that's what this forum is for.
Factory reset it and redid it...all set guys!When you calibrated the radio, did you set the throttle limiter to 100% and set all trims to 0/centre? If not, you'll need to calibrate it again
After this is done, you can calibrate the ESC too. This is from the Arrma 4x4 BLX manual:
The forum seems to be for people that are too lazy to read. If your statement is true.Certainly have sir...the videos I saw weren't very informative...plus, what's the forum for pal?
