HI Guys,
I just picked up a cluster of bolts of a project, which eventually will be known as a Mugen MBX6 ECO. I'm looking to swap whatever I like into the Senton, once I get this all straightened out. Everything looks to be complete and half working, but ANCIENT, aside from the motor/ESC, that's fairly recent. TrackStar 1900kv and XErun SCT PRO
Hoping some of you guys can help me out real quick. When I power the car on, the servo (JR Racing Z650M) works great. I have endpoints set great, dual rate set just where I want it. With weight on the wheels, it turns them effortlessly. Trouble is, after a quick forward pull, the servo acts very erratically. The trim is all out of whack (right and left and all over the place) and I have 10% steering, if that. The servo sounds like it's moving fine, but it will not move the arm at all. Bolt in arm is tight. Turn the car off and then back on, it's perfect again. Very strong, complete throw of the servo.
Any ideas?
I've been reading up on using capacitors to hopefully help with issues like this, but I don't understand how this setup on the battery wire would help. I plugged it into the battery port in the receiver, but it keeps the ESC on all the time, and made no difference
Any ideas?
