So m6 kraton exb esc decided to idk crap itself in the middle of a run. I went back home and started to do the fixes i heard off none of them were giving results. Its like m6 esc was trying to do the calibration and something else at the same time if i held the set button and powered it on it would make that failed beeping sounds. I found another fix while scouting the forum and it was to remove the blue wire and try give it throttle and give it gaz. Nothing happened in the first attempt but suddently the esc went solid red and started making a duzzing sound. Shuted it off and it made a weird smell. Me being me i tried a second time this time the motor started to finally rock back and foward but it started to make that o no sound and shutted it off before i menaged to put the wire back in. Again weird smell but gone after i vent it out. This seems to be a dangerous process If you ask me. The esc is malfunctioning and we are forcing it out of it. Mmight work but in my case it was maybe about to work but the esc went into overloading itself. I don't want to try again at this point atill power on like normal and flashes green. Maybe someone has done this and what exactly is happening?
