i think you will be fine with that setup. The only thing is you might have to mess with the gearing (bigger pinion) to compensate for the lower kv motor. Or get a 4s esc like a Spektrum 130a. Flip side like @Raginbull74 mentioned get a higher KV motor.Hey guys, I have a blx 100 esc and a blx 2400kv motor. They are extra and I wanted to build a granit from it. Will there be any issues with a lower kv motor? Will I blow out the esc?
RCJuice usually has them for a good priceI will check out the hobbystar motor right now.
Should be fine.Will there be any issues with a lower kv motor? Will I blow out the esc?
