I could get it running again , I plugged the motor of the esc tried and I plugged out all 3 diff brains now its running but without diffs I don't know if they are locked or unlocked but I could drive again@Nampur I would suggest doing a factory reset if you can on the ESC.
To reset the ESC to factory default settings connect a battery, turn the transmitter on and then turn the car on. Press and hold the set button for 4 seconds and release. The Red and Green lights will flash simultaneously to show you have reset. Switch the ESC off and factory reset is complete.
How old is the ESC? It might be under warranty.
You can only lead a fish to water.Battery is too small. You need a 5000mah 35C minimum. You are hitting LVC because it’s too small.
I spoke to horizon hobby and they didn’t say anything about the battery size, could you tell me where you found that?Battery is too small. You need a 5000mah 35C minimum. You are hitting LVC because it’s too small.
Page 15 of your manualI spoke to horizon hobby and they didn’t say anything about the battery size, could you tell me where you found that?
Thank you, I’ll have take a look today to see if that solves the problem. For the first couple runs it worked just fine. Ran for maybe 20 minutes. I had the battery tested just to make sure it wasn’t that. Wondering why all of the sudden it would be an issue.
Lipos deteriorate over time. It may have been borderline OK at first and now it isn’t up to task. Also cold weather greatly affects lipo performance so if it worked when it was warmer out, then it may be due to cold?Thank you, I’ll have take a look today to see if that solves the problem. For the first couple runs it worked just fine. Ran for maybe 20 minutes. I had the battery tested just to make sure it wasn’t that. Wondering why all of the sudden it would be an issue.
I have only had the car and battery for a week. Pretty consistent temps where I’m at. I’ll have to get in touch with horizon again and see if they will ship out a new esc.Lipos deteriorate over time. It may have been borderline OK at first and now it isn’t up to task. Also cold weather greatly affects lipo performance so if it worked when it was warmer out, then it may be due to cold?
I have the same issue, brand new running 3300 battery it came with, out of the box it ran fine, next day it stops and is flashing after 5 mins, switch off and on and in less than a minute does it againThank you, I’ll have take a look today to see if that solves the problem. For the first couple runs it worked just fine. Ran for maybe 20 minutes. I had the battery tested just to make sure it wasn’t that. Wondering why all of the sudden it would be an issue.
Yes, I have the mega 550 senton brushed and cheap 3300 batteries. My buddy has the other cheap one the granite and has no problems, thanks for the reply!Am I safe to assume that you have the Mega? Do you have the esc in NIMH mode? The Mega esc and motor are just like any other rtr brushed system, they make good paperweights.
Will try that, thank you, for 200 bucks I'm not impressedNothing wrong with the brushed Mega versions. Great starter rigs.
Try the reset process for the ESC.
I AM impressed, its a great rcWill try that, thank you, for 200 bucks I'm not impressed
